TwinTurbo.NET: Nissan 300ZX forum - Re: how much pressure did you apply? about 5psi is enough.
earthpunk
on August 05, 2010 at 8:22 PM
how much pressure did you apply? about 5psi is enough. (n/m)
posted by tognot
on August 05, 2010 at 03:13 PM
I read ~6 psi on my aftermarket boost gauge (which is connected to the driver's side plenum) during the pressure test while at steady state. Thanks.
Pressure Test / Leak Test Reveals leak at EGR valve...
earthpunk
02:50:28 08/05/10
tognot
15:13:06 08/05/10
Re: how much pressure did you apply? about 5psi is enough. -
earthpunk
20:22:03 08/05/10
The EGR leaks very little around the valve stem by design
Zarcasm(Hfd, CT)
22:01:24 08/05/10
Re: The EGR leaks very little around the valve stem by design
earthpunk
11:35:24 08/06/10
Re: Re: The EGR leaks very little around the valve stem by design
earthpunk
02:39:37 08/08/10
I heard a very small leak on around the EGR when
Gordo 93TT Daytona
13:55:34 08/08/10
Good info. Thanks!
earthpunk
19:46:09 08/08/10
